New Member
Vitca12
11:12 PM
NJ
New member from NJ. Thanks for the add. I currently have an A12 RR in Vit C 4spd.
I have already found this site to be very helpful and would suggest it to anyone with a Mopar. DSCN2560.JPG
Welcome from NY.
Everyone needs a dose of vitamin c occasionally
Beautiful car! The first Hi Impact color available I believe. My ‘70 E87 D21 Shaker ‘Cuda is K2.
Welcome from Illinois!! Your A12 is . . .
For those not already aware of what the A12 option included, read on . . .
The A12 engine conversion package was a mid-season release for 1969, and was available for the Road Runner and Dodge Super Bee. It consisted of the M-code 390-hp 440 6-bbl engine (Six-Pack in the Dodge), fitted with three Holley two-barrel carburetors on an Edelbrock aluminum intake manifold. Though the forged steel crank and rods and the 268/284-degree cam had the same specs as the 375-hp 440, the crank was specially selected and shot-peened, the rods were Magnafluxed and the cam was Lubrited and featured low-taper lobes. New flat-faced lifters worked with the lobe design. Also added were Moly-filled top piston rings, flash-chromed valve stems, higher-load valve springs, heavy-duty rockers, a Prestolite dual-breaker distributor, Hemi oil pump, viscous drive fan and 26-inch radiator.
A fiberglass lift-off hood with a "Super Stock" air scoop was painted in a textured semi-flat black called "Organosol" and was retained by four pins--no hinges, no latch. Regardless of transmission choice, Hemi four-speed or optional 727 TorqueFlite automatic, the 9¾-inch rear with Sure-Grip and 4.10 gears was included. The suspension was Hemi-spec, and the brakes were HD 11-inch drums (discs not available), larger 15-inch wheels were black with chrome lug nuts, and the tires were chunky G70-15 Goodyear Polyglas Red Streak. Three-speed windshield wipers were a mandatory option.
The A12's strong performance image was backed up with 13-second ETs in street trim.
Welcome from New Zealand.
That's a fantastic ride you have there. Some more photos would be great.
Nice RR too, love that color
Welcome to FBBO from western NY!
That's one sweet RR you got there :thumbsup:
