Propwash
- 5:05 PM
- Oct 29, 2009
- Island of Misfit Toys
Up for sale is a New Pertronix Flame-Thrower II Billet Distributor for RB Block Mopar.
Pertronix Flame Thrower II Distributors feature the patented Ignitor II (electronic ignition module) with adaptive dwell control and integrated Hall Effect circuit that is triggered by cobalt magnets for stable timing and precise spark distribution. A powerful micro controller with adaptive dwell algorithms allows the Ignitor II to adjust the dwell angle in order to maintain peak energy throughout the entire RPM range for increased high and low RPM performance. Because peak current level is reached just prior to spark, ignition energy is sustained with less heat buildup in the coil and module.
Pertronix Flame-Thrower Flame Thrower II Billet Distributors Features
Compatible with most capacitive discharge systems
Available with or without vacuum advance
High dielectric strength cap with female or male brass terminals
Caps available black or red
Premium rotor with brass contact
Polished billet aluminum housing with 0 to -0.003 tolerances
Tempered distributor shaft with low torsion displacement for accurate timing and longer life
.500'' Diameter Shaft on GM Applications
Upper ball bearing and lower bronze bushing reduce friction and high-RPM vibration
Durable Heat-Treated Gear
Precision stamped advance weights eliminate erratic timing
Factory-set performance advance curve (additional springs included for custom curves)
Adjustable mechanical advance with proprietary limiting functions for multiple settings
50-state legal via EO #D-57-12 except for distributors without vacuum advance
I ended up having to go a different route....These go for $275.00 at Jegs/Summit. I'll let it go for $225 Shipped (in US)..save yourself $50 bucks and the shipping.
Thanks for the ad FBBO and thanks for looking.
