- 3:20 AM
- Jan 29, 2018
- Midland Ontario, Canada
some people try to sucknblow with there valves closed when they should be keeping their mouth shut! I've been guilty before and probability to repeat is high!This is one of the problems with the internet, trying to diagnose problems based on the written word. Based strictly on the OP's comments I agree that either there are no push rods on the drivers side (possible but unlikely), they are the wrong ones i.e. too short (unlikely) they are all bent (possible but unlikely), the rockers have become loose of fallen off (possible), or the drivers side cylinders are not getting any spark (pretty unlikely).
I bought a used 440 last winter and I put it in my 70 road runner last weekend. Here is my problem. I got it fired up and it seemed like it was only running on 6 or 7 cylinders. I ran it for 20-30 minutes, turning it off occasionly to check timimg, etc. I noticed that the exhaust manifold on the passenger side was very hot to the touch. Yet the driver side was hardly even warm. I could hold my hand on it becasue it was so cool!. I started it again and crawled under it to check the exhaust coming out of the exhaust manifold(there are no exhaust pipes on it yet) Almost nothing was coming out of the driver side but on the passenger side it was coming out stronly and it was hot. I am going to start on it this morning and check it out some more. I was thinking blown head gasket, cam lobes worn? Everything is new, cap, wires, electronic ignition, spark plugs. I checked the firing order again thinking I messed up on the wires, that's okay. It idles and revs up okay, other than having a slight miss, but it could be better. I did not drive it because I am waiting on a driveshaft. Any ideas guys? Thanks, Steve
every response to this guys problem was 100% legit and very well could have been the answer given the information that was provided. what kind of an idiot cant tell the difference between an 8 cylinder hitting on all 8 or barely surviving on 4 cylinders at 350 rpm? then we are just going to keep on running it. this turd isn't qualified to use a flathead screwdriver
I would not have put an unkown motor in. Too many stories of just rebuilt, or ran strong before I pulled it.I bought a used 440 last winter and I put it in my 70 road runner last weekend. Here is my problem. I got it fired up and it seemed like it was only running on 6 or 7 cylinders. I ran it for 20-30 minutes, turning it off occasionly to check timimg, etc. I noticed that the exhaust manifold on the passenger side was very hot to the touch. Yet the driver side was hardly even warm. I could hold my hand on it becasue it was so cool!. I started it again and crawled under it to check the exhaust coming out of the exhaust manifold(there are no exhaust pipes on it yet) Almost nothing was coming out of the driver side but on the passenger side it was coming out stronly and it was hot. I am going to start on it this morning and check it out some more. I was thinking blown head gasket, cam lobes worn? Everything is new, cap, wires, electronic ignition, spark plugs. I checked the firing order again thinking I messed up on the wires, that's okay. It idles and revs up okay, other than having a slight miss, but it could be better. I did not drive it because I am waiting on a driveshaft. Any ideas guys? Thanks, Steve
I think the first thing I'd do is a compression test.I bought a used 440 last winter and I put it in my 70 road runner last weekend. Here is my problem. I got it fired up and it seemed like it was only running on 6 or 7 cylinders. I ran it for 20-30 minutes, turning it off occasionly to check timimg, etc. I noticed that the exhaust manifold on the passenger side was very hot to the touch. Yet the driver side was hardly even warm. I could hold my hand on it becasue it was so cool!. I started it again and crawled under it to check the exhaust coming out of the exhaust manifold(there are no exhaust pipes on it yet) Almost nothing was coming out of the driver side but on the passenger side it was coming out stronly and it was hot. I am going to start on it this morning and check it out some more. I was thinking blown head gasket, cam lobes worn? Everything is new, cap, wires, electronic ignition, spark plugs. I checked the firing order again thinking I messed up on the wires, that's okay. It idles and revs up okay, other than having a slight miss, but it could be better. I did not drive it because I am waiting on a driveshaft. Any ideas guys? Thanks, Steve
I built an engine for a van project, 350 sbc- sorry ! It was a 1-Ton 4x4 project a got myself into - anyway, no exhaust out 1 side - pulled the heads twice , couldn't find anything ! Woke up @ 3am the next night when it hit me - the old engine was so bad it clogged the exhaust manifold in the curves and couldn't see the carbon - it had to be a van, I'll never forget that one - 2wks of tortureI bought a used 440 last winter and I put it in my 70 road runner last weekend. Here is my problem. I got it fired up and it seemed like it was only running on 6 or 7 cylinders. I ran it for 20-30 minutes, turning it off occasionly to check timimg, etc. I noticed that the exhaust manifold on the passenger side was very hot to the touch. Yet the driver side was hardly even warm. I could hold my hand on it becasue it was so cool!. I started it again and crawled under it to check the exhaust coming out of the exhaust manifold(there are no exhaust pipes on it yet) Almost nothing was coming out of the driver side but on the passenger side it was coming out stronly and it was hot. I am going to start on it this morning and check it out some more. I was thinking blown head gasket, cam lobes worn? Everything is new, cap, wires, electronic ignition, spark plugs. I checked the firing order again thinking I messed up on the wires, that's okay. It idles and revs up okay, other than having a slight miss, but it could be better. I did not drive it because I am waiting on a driveshaft. Any ideas guys? Thanks, Steve
no critism, just that dual planes aren't exactly left/right there more of firing order alternate or best the plumbing can be accomplished in a compact pakage to keep the engine power balanced!Dual plane intake, check to be sure right side isn’t blocked. If not, pulling the valve cover is the next step.
