Magnes
- 11:33 PM
- Nov 14, 2013
- in the Houston Texas area
I've been working on this 72 Plymouth Satellite Sebring Plus 80K mile survivor car. It was in a dry storage building since '97. Just got it out a couple weeks ago and have been getting it back into shape. Everything is there. I have it running now but there is a few electrical gremlins and I am looking for possible fixes.
Here's my problem:
Headlights do not work. High or low beam.
Gauge lights do not work. (Rallye gauges)
Radio does not work.
Horn doesn't work (but I think that's a bad relay... not 100% positive but I can hear the relay click when I hit the horn buttons) and the key buzzer isn't working on that relay.
Tail lights do work.
Brake lights work.
Parking lights work.
Blinkers were working somewhat, they'd blink weakly... Kinda weird but you'd see the blinkers on the opposite side trying to blink at the same time. So if I hit the blinkers for a left turn, they'd blink (but not brightly) and if you looked closely you could see the right side blinkers either dimming down or trying to blink as well. - But now, no blinkers at all. No flashers either.
The headlight switch feels kind of worn when you turn it side to side for, what would be, dimmer adjustment.
I've checked and cleaned wiring. Checked fuses. Checked hi beam switch (pulled it, cleaned it, wasn't dirty).
The only thing weird thing that I am seeing is the only wiring hack on the whole car. Apparently been done by a previous owner... They have a wire running from the brake pedal switch under the dash to the trunk area and it's tapped into the wiring back there. But it's just tapped into that wiring and nothing is disconnected back there. The brake lights work, so it may not be related to the issues I am having, I just thought it was worth mentioning.
Maybe I'm missing something and just wanted to run it by you guys. I appreciate anyone who takes the time to try and help.
Here's my problem:
Brake lights work.
