70sixpack
When you say you have to disconnect it and and plug it into the bottom terminal on the starter relay, where exactly are you disconnecting it from? That center pin in the NSS needs to be plugged into the ground terminal on the starter relay marked "G", which is to the bottom right I think.
My neutral safety switch is a round male plug that plugs into a female end. I think it is a black with green tracer wire, but not sure since I do not have the car here at work. I know from looking at pictures that I took of the car before the restoration the wires were connected, now I have to run it to the starter relay.
