NZ 70 RR
- 10:55 AM
- Jul 11, 2013
- Nelson, New Zealand
More great work
Been slow with updates, sorry.
Tue 10th - Barry(panelguy) cut some metal and took it into town to his ex-work and used their folder to shape it into a filler panel support brace. He brought it home and did the final shaping.
Next he patched up the other rust hole in rear window frame.
On to the drivers front guard. It is a replacement one off a Satellite so had holes for the side moldings. Barry welded these and then dollied out a dent in the nose of the guard. Couple of small dents later and guard finished.
Passenger guard, needs lot more work. Ended day by dollying out a large dent.
Thur 12 - Barry spent the whole day on the passg guard. It had 3 dents in the side and 1 on top. It needed a new metal patch to the skin where guard attaches to sill, and one higher up.
Fri 13 - Finished guard in morning. Drivers door next. This needed patchs to both bottom corners. Outside only on 1 and inside/outside on other. He also cut out the damaged metal where mirror sits and replaced with new metal. We will drill holes later. Finished all this before days end so started on Pasg door. Bigger job. Bottom of door skin needed to be replaced so he cut 2in off. A section of the inside was also removed. He cut some new metal and took it with him.
Tue 17 - Barry stopped at his ex-work on way out and folded the edges of the new metal. He fitted the inside patch and then paneled out dents in the skin while he had good access to them. He finished day by starting to weld the outside skin patch in. He welded the corners first and then did small sections at a time on outside. He had drilled holes and used self tapers to hole the skin and patch in place. Then used grinder with cutting wheel to get small gap to weld. 80% done by end of day. I cut some rusty metal out of driver A-pillar and made patch for it. Also opened up and cleaned rust of pasg A-pillar just below front windshield.
Wed 18 - Barry finished the door. Excellent result, really pleased.
Repaired the pasg A-pillar and then the drivers. Final 2hrs of day he started to make a patch for the rear tail section, pasg side.
Lower tail panel needs work, do this after blasting.
