Oil Pan Swap
bulldog
5:44 PM
Ontario, Canada
Is it possible to change my oil pan,without pulling the engine, on my 67 Coronet, with a 318 poly engine in it. Just found out the pan has a hole rusted through on it. Causing a small leak that I'm sure will get worse.
Does anyone make a new pan for this ?
pull one tie rod end off spindle, then pull center link from pitman & idler arm, swing entire assembly out of the way, then you can drop pan. Any 273, 318, or 340 pan will fit as long as sump is in proper location.
360 pan will not work, those have larger main caps
Bryan
