The 361 pan is made to fit the 62-65 cars, so yes its a better fit than the 66-72 "B"s. Switch the oil pickup as well. If your 361 items are in bad shape, new stuff that is a proper fit is now available as well for 62-65 cars. HTH, Lefty71
At one time they were available from Mancini.That's where I got one from. Possible that Vans Auto may have them.
Reusing the 361 pan is for 2 reasons. First is the 70 pan will hit the right side corner of the K frame ( or come very close to it)thought the K can be notched.
Second the drag link of the early B's will rub the 1970 pan as it is a bit deeper at the back of the pan.You can shim the engine mounts to clear.
The windage tray will fit with a lot of trimming, almost not worth using. Reproduction max wedge pans are available, something I’d look into. PM 69bfan on here, he has them. Also I think Mancini carries them among other vendors.
