Oil pickup and crankshaft clearance
PolaraFury
9:39 AM
MN
Putting my stroker back together after a trip to the machine shop. I broke the oil pick up off in the block.
How much clearance do I need between the crankshaft assembly and the oil pickup.? The base of the new oil pickup is thicker than the one I broke, so I’ll need to grind some clearance.
Thanks
My crank scraper is set at .060" from the crank. If the pick-up is rigid it doesn't need much.
