Old problem
1967 GTX 440
4:43 AM
buffalo New York
I have 1967 gtx with 77 440. Motor was rebuilt before it was installed. It ran good for about five years. Out cruising one night, ignition cut out and came back on, muffler exploded. limped it home. new muffler and msd distributor. Though it was fixed. Then had off line stumble. Check valve train, no problems. Then took cylinder heads to machine shop, they changed valve springs and r & r valve guides. Now runs ok but down on power. What could be wrong? Thanks
Welcome from Alabama, 67 GTX's my favorite. Did the accelerator pump on the carburetor get changed or repaired after the backfire?
Check your timing, could be a bit late. Also check a/f ratio to make sure it's not running overly rich.
Check your ballast resistor to make sure it isn't cracked. I had similar issues years ago, and found that simple cheap and easy fix after going through a bunch of other stuff...
Welcome from Missouri!! I suppose if enough unburned gasoline collected it could blow up your muffler. Bad spark plug wires, shorted coil, fuel mixture problem or a cracked distributor cap. Good luck!!
welcome to FBBO
was the power loss same time ?,
when you went from a Holley to the Edelbrock ?
that may be a really good hint right there
there's so many things it could be, related to fuel delivery, filter,
clogged sender/pick up sock or restricted lines, bad pump
wrong ignition timing, bad coil, too much air-gap (needs 0.008-0.010")
on the pick up, bad wire/s, bad plugs, etc.
did you do any kind of compression test ?
or any other types of diagnosis ?
anything to actually narrow it down ?
are the simple things covered, plugs wires cap rotor all good ? etc.
do you still have a restriction in the exhaust ?
all these things needs to be addressed in you new thread
maybe start a new thread in another/proper specific forum section
or even the general discussion section
this is the welcome wagon & not a Q&A tech section
far less viewers too
good luck
