64 polara 500 its the bright read from legendary the now I have is a dark red repopWhat year, model, and what colour is your pad supposed to be. We sprayed our black dash with PPG Hot Rod black using a flattened.
Dash pad, I used SEM prep, and SEM Colour Coat flexible coating. Have also used Herb`s. There are others also.
wow looks amazingView attachment 1052208 The herbs dye worked great to cover the tan dash I bought. In fact worked and looks 10x better than I expected it to be.
If you want a dead on match get the color lot code from Legendary and call Kolor Korrect in NJ. They will mix it for you. Check out Bull dog adhesion promoter also.64 polara 500 its the bright read from legendary the now I have is a dark red repop
@JackRView attachment 1052208 The herbs dye worked great to cover the tan dash I bought. In fact worked and looks 10x better than I expected it to be.
@JackR
Do you remember which color that is?
