Why are you wanting to put in all new glass? Just curious, because I have seen some of the new stuff out there, and its no where near the quality of originals from the era, or even replacements from the era. Most door glass I have seen is wavy along the edges.
Ok, a couple of things. First off, the front windshield, and the rear glass, the butyl is a pain in the ***, its best to remove while warm, and its recommended to use a piano wire to cut through it to separate it and then remove and its tedious work. My windshield was seriously cracked, so I was not concerned about keeping in tact, and I got a 521 restoration windshield, that came from AMD, and its pretty darn good. I had the new windsheld installed with modern sealant, but i did reinstall the back glass with butyl, and again, tedious work.
The rest of my original glass I polished out the fine scratches, it took some work but they cleaned up pretty good. There is a current thread about polishing glass on the site here, check that out, may be helpful, but remember, deep scratches will not come out, but the dull feather like wear for say the window sweeps can be improved. Regarding the quarter glass, you can get new seals that slide into the trim piece, and that trim piece can be polished, that's what I did and they turned out great.
Here is a link to the quarter glass seals http://www.mopar9999.com/FCStore2008/shop/item.aspx?itemid=1187, I am sure there are other places that have these, but pretty easy to replace.
Hope this helps!
The ’71-72 glass has a different shape than what is pictured, and there are no holes along the front edge for any kind of fasteners. It’s a pressure/interference fit, never seen any sign of adhesives used originally.
eeehm, need to note 71 are diff from 72s even the same quarter opening shape.
71s are small squared mounted on a pot metal bracket or frame, for a while 72s are big glass with the hole for the fasteners to the chanels sliders, just like fronts.
quarter glass posted seems to be A body fastback
and about the trim... need to remove weather strip, which are slided into holes to the body... then will reach the outer molding bracket screws.
before that, of course all the interior trim
This is talking about hardtops. Actually not sure if coupes are diff.
