Geoff 2
I presume that is a hyd cam. If so that will need about 40-45* at idle. Yes 45*. A 440 I built has a 248 @ 050 sol lifter cam, which is close to your hyd lifter cam. It idles with 43* of timing, achieved by using vac adv. Made 605 hp with TF240 heads & a 850 TQ carb.
Try this 5 min test. Engine idling, in gear if auto, rotate dist slowly advancing the timing. When you get to the highest rpm, stop & check what the timing is. That is what YOUR engine needs for best idle & tip in response.
