GearAddict
I'm installing a new master cylinder that came with a new adjustable pedal rod. when I went to install it, the pedal to rod attaching bolt is very tight going into the rod, to the point that it won't go in unless I press it in with an arbor. The bolt shank has plenty of play in the old rod and drops right in, but I don't know if that's due to wear.
Should it slide in and be able to spin in the rod?
If so I'll have to return and get a replacement.
