1carlover
Brand new! This is Pertronix pt#D7143710 one wire plug and play billet unit that was set up by FBO systems to run in a big block with Comp cams 585 lift hydraulic roller and 3:23 street gears on 26 in tires. It was installed with a new set of plug wires in my 440 but never ran the motor due to an oil pressure issue. I also have the roller cam and set of Comp. hydraulic roller lifters available.
Asking $300 for the distributor and set of made to fit 8mm 440 plug wires. $600 for Comp cam and lifter setup. Hit me up at here or carldno1 at Verizon dot net. for ease of sending you pictures. Thanks Carl
