Photos of embelms help!
Mopardrt
10:52 PM
Detroit
Hey guys I need photos of all the emblems/decals that belong inside and out of the 1974 plymouth roadrunner
Here is what the P-side wood grain panel with emblem looks like, If it has air conditioner there will be vents included in it.. You may want to look up 74 RR stripe kits in Year One, It will give you an idea what they look like and prices, unless your going to paint them on, Im not sure but ive been told the roof strobe is solid on a 74 where 73 is broken up... hope this helps some, im sure someone can tell you exactly what to get for a 74.. Good luck.
Also, depending on how "correct" you want to be theres more than one stripe kit option, depicted on the fender tag. De-coding it will tell you the stripe style and color.
Ex: on my 74, weird combo, originally it was green body color, with white hockey stick that ran over the roof, and white call outs on the budge hood,
The 73 and 74 Roadrunner have a lot of stickers!
1. There is a roadrunner badge as Ron 73 shows on the passenger side dash insert, ac or no ac. these are not made new, you will have to find a used one if your is missing.
2. The center of the steering wheel has a road runner head button.
3. insert key sticker on the sterring column.
Thats it for the inside!
The outside stickers and engine bay stickers are a plenty aside from the bird in circle on the front, engine size on the buldge, except 318 cars, the running birds on the side of the "strobe" stripe kit, and the standing bird on the passenger side of the trunk lid with "road runner" name plate below it, there are many others.
Best thing you could do is call Year One they can set you up with what you need.
I have purchased every sticker for my 73 from them, i think its about 25 different stickers ranging from the outside emblems and stripe kit to the "insert key" and jack base sticker to coolant and engine specification decals and even the air filter maintenance sticker.
good luck!
Phoenix Graphics may have a kit that could show you the strobes on the outside...she has pretty much has EVERYTHING and very correct too...not sure if it spans to the early-mid 70's MoPars tho...
http://www.phoenixgraphix.com/
There are reproductions of the dash badge being made, but they aren't cheap. The ones I've seen are about $65.
Can you tell us who makes them, its been a long while since i tried finding one but couldn't anywhere.. I know of one guy here that had one if you guys want to try.. Not promising he still has it but i could check for you no problem, its the whole wood grain piece with the emblem on it...
