Pics of Trans and Rear End/Can U Tell
FlagCraig
8:07 AM
Tennessee
I have attached a pic of trans and the rear end. Can anyone tell if its a 727 TorqueFlite and is it an 8 3/4 rear end. I'm not that good.
By the shape of the pan, looks like a 727. And the 8 3/4 rear is smooth on the back, bolts on the front (driveshaft side) if I'm not mistaken.
What Cuda said, Trans is 727, has the bump our on the pan. If the trans pan was more of a square it would be a 904.
Axle is 8-3/4. It is the only chrysler axle where the center section unbolts.
The rear axle shaft bearings are greased, and should be checked on any old used car because the bearing holds the axle in the housing (No "C" clips.)
I just mention it because I had one go out on me a long time ago, and the entire axle/brake/wheel came out of the axle and dropped the car on the brake backing plate.
