Pieces of something under 383 valve cover??
MikeyM
6:09 PM
NorCal
Hello again, happy Sunday.
In changing valve cover gaskets today, I found these two lovely pieces in the front lower portion of the passenger side cylinder head when I remove the valve cover. I cannot see any visible broken pieces so I am assuming they have come from somewhere else? I realize this is a longshot, but might anyone have any idea what these pieces might be part of?
Thanks very much,
Mikey
Crap.
X2 the umbrella seals over guides . Hope none partially plugging pickup? She smoke a little at start up and then goes away?
Yup. Not always but sometimes. Blue smoke, too. Oil.
Well, winter is upon us so might as well put her to sleep for the season and git er done.
Thanks, everyone,
Mikey
That's how I lost the 440 in my Hurst 300. Ran great, but ended up taking out the oil system. I was a dumb kid, and hadn't taken the valve covers off. Didn't know what the chunks were, in the drain oil.
Definitely not bueno. Can the oil pan be removed with the engine in the car??
Edit - looks like so, with patience and a little finageling, if the center link is removed. Any tips on this? I have read a couple older posts on it.
Missile - did the seal pieces plug your oil pick up?
I have dropped the pan with 440 still in my '64 Polara. Tie rod needs to be dropped. Some of the pan bolts around the front corners of the pan can be hard to get to, but will come out. With the pan off, you might consider adding a windage tray, if your motor does not have one.
Stem seals can be changed without pulling the heads. You will need an air hose fitting that screws into the spark plug hole, to hold the valves closed with compressed air. You can then collapse the valve spring with a special spring compressor. This will allow you to pull the valve stem locks and retainers, then the springs. It is a tedious job (16 times), but can be accomplished with moderate skills.
Crap.
Thanks, everyone,
Mikey
Sent you a DM on tr interior piece
Thanks MWB but I didn't receive it - likely because Im at 100%. This will sound lame but how the heck do you delete DMs? I tried selecting certain messages but I can't find any way to delete them.
Thanks,
Mikey
Yup, I did an engine rebuild years ago for exactly that.
Yes, you can, and should remove the oil pan. You can swing the centerlink out of the way to remove the pan.
Thanks,
Mikey
Not to get off subject on your guide seal issue but tomorrow I’m going to look at the parts my buddy has for sale gonna take pictures and a list and I’ll post it. I’ll check on your door card trim pieces as well. There should be a way somewhere on here to search how to delete your DM’s, I’ll get a hold of you either way Mikey.
Select show all direct messages than select the square for the message you want to delete and then at the bottom option drop-down select the action leave direct message.
Then you will need to choose delete forever or delete and allow it to come back if responded to.
Thanks all, very much appreciated. I'll get those messages cleaned out :)
Yes.
