Poor idle, possibly vacuum advance,points
11:48 PM
Crested Butte Colorado
Hi, my name is Beckett and I just signed up because I need a little advice. Owned several mopars over the years. Currently have two Roadrunners, hard top and a rag top. Currently having issues with the hardtop. Ran perfectly, then went on 250 mile round trip. It developed poor idle, hard start, then would die after 5 minutes. Checked carburetor, fuel filter. Possibly vacuum advance, points? Why will it run for 5 minutes then die?
15C6CE28-1253-4144-9D9B-35D388326FC1.jpeg A1F09A25-03AA-4D86-BE04-9255F2C7D01F.jpeg
Have you adjusted the carb? Checked for vacuum leaks? Adjust carb with a vacuum gauge to get max vacuum. Trash in the carb? Lots of things it could be. Simple thing to do is check for vacuum leaks and go from there. When it dies will it fire back up? Maybe check your coil and or heater resistor. Make sure you have good voltage to the coil. Buddy of mine had the electric choke hooked up to the coil and that was a no no..
It runs poorly you should sell it to me I'll take the junker off your hands.. :)
Is the choke adjusted properly? You might have a problem with a broken bimetal spring. If its borken your choke plate could be flopping around after its warmed up thus killing the motor. Just a thought
after the motor dies I would immediately check to see if you still have a good fat spark, by grounding a spark plug and cranking the motor over, next I would check to see if you have fuel coming out of the squirters in the carb when you pump the carb. At least you will elimate spark and fuel problems. For an engine to run you need spark, fuel, air and compression. Next I would check your wiring out to make sure there is no conections that are not making a complete circuit or shorting out, causing you motor to shut down. If you find a problem with any of these situations you can look at the individual problem and work from there. Did you check to see if the exhaust Manifold Heat Control Valve on the passenger side exhaust manifold is stuck closed or partially closed? The manifold heat control valve assembly, (heat riser) is often overlooked as the source of low speed engine performance issues, which is a serious mistake. This simple device is essential for smooth engine operation, even in warm summer weather. The reason is simple physics; converting a liquid (gasoline) into a vapor (air/fuel mixture) requires the application of heat. Start your car on a cool day and watch the base of the carburetor; it will become frost-covered for a short period of time as the engine warms to operating temperature. The ambient temperature of air entering the engine will drop as latent heat within that air is consumed in the process of vaporizing droplets of liquid gasoline into the combustible air/fuel mixture. The manifold heat valve forces hot exhaust gases up around the base of the carburetor and the intake manifold plenum, (the central area directly under the carburetor) to warm the mixture. If additional heat is not supplied, the gasoline can easily condense back into a liquid as the air/fuel mixture comes in contact with the inner surfaces of the intake manifold. This “leans” the mixture causing rough idle, hesitation on acceleration and stalling. As the engine warms to operating temperature, less heat is required and the manifold heat valve swings open, allowing the exhaust gases to flow directly out into the exhaust pipe.
Starting a cold engine requires a very rich mixture for the very same reason. The manifold passages are so cold, the only way to get enough air/fuel mixture to each cylinder is by use of the carburetor choke. The majority of gasoline drawn into a cold engine condenses on the walls of the manifold and never reaches the cylinders to fuel the engine.
welcome to FBBO
Welcome from Canada, had that kind of problem a few times, in my case it was the sock on the fuel pick up in tank
Welcome from Ohio.. There’s always help available on FBBO!
I always thought points are set at .019-.020 ??
Your plugs are ..035
Set points before timing is checked & reset
