Possible to install ‘wrong’ balancer?
///Matt
10:48 AM
Texas
been searching but can’t find an answer...
Is it possible to install a “for cast crank only” balancer onto a forged crank (440), and vice versa?
Not that I want to install a ‘wrong’ one, I just want to rule out or find possibility that my car has the “wrong” damper on it.
I’m also finding vague and conflicting information about 76+ RV motors as possibly having one crank or the other, though still using a “cast only” balancer. It’s confusing.
Yes it is possible. I bought a charger years ago. It had just a slight vibration when you rev it up. I checked the numbers. It was a 69 383 with steel crank "internal balance" but it had cast crank balancer. I changed the balancer to a internal balance. Problem solved. Smooth as silk when revved up.
Perfect.
I found some more info suggesting that RV motors (which i’m pretty certain mine is) generally had forged cranks and “6-pack rods”... guess I’m boogered into pulling the oil pan and being sure. I hate breaking seals that don’t leak, haha.
But if it’s a forged crank, I’d rather put a forgrd crank balancer on it.
You can check for weights/no weights on the torque converter. Easier than pulling the pan. If you have a bore scope you can check through the drain plug hole for the type of crank. There's a difference in appearance between the cast and forged just by looking at them.
Are you having any vibration problems? If not, you probably have the right dampner.
I do have vibration... many. hard to nail down between motor, trans, driveshaft, tires....
I believe there are three different damper weights, not counting the thick hemi balancers. There is, no counterweight, for standard rod forged crank, heavy counterweight for cast crank also using a weight on the converter, and one with smaller counterweight for forged crank with heavy "six pack" rods. I don't think the heavy rod motors use weight on the converter, but I may be wrong about that.
I don't know how to tell if you have a heavy rod motor, other than physical I nspection.
Thanks guys. I know which balancer it has... just gonna have to get into it and be sure what internals it has.
I did find (under paint) the deck stamp, which, as best I can decode, indicates it was originally a cast crank based on the “e”, but I could easily be wrong or it could have been changed out at some point.
Buy a small bore camera for you phone and look in through the oil drain plug hole. It about $20
