Triplegreen500
 - 7:30 AM
 - Dec 3, 2020
 - western Maryland
So, a previous owner of my '70 Charger decided they wanted Dixie horns, and tapped into the dash wiring to install their own horn relay / push button / wiring setup to power and activate them. The factory horns don't work, but that's another topic I'll deal with once I identify the wires they cut up. It's a small bundle above the parking brake pedal, factory taped into their own little "branch" of wires. There's a pair of heavy-gauge dark blue with white tracers, connected together with a factory ring terminal; there's a pair of light green (I assume - they look like hi-viz safety clothing so I don't think they're "yellow") that are cut and separated but may belong connected to each other; there's a black with red tracer; there's a dark blue with yellow tracer. The only thing I can find in the wiring harness diagram (I downloaded one from mymopar.com) with those specific color codes, looks like the concealed headlight relay...but my headlights work, my high beams work, and my doors work (although they SLAM shut, I need to try and address that - might just need new rubber bumpers).
My question - would all this stuff work, if the relay is missing? What is the relay's job? I know what a relay does - it uses a small voltage signal to trigger a larger-voltage circuit to keep a high current draw out of a switch or button - but if everything is working headlight-wise on my car and this relay is missing...is it redundant to something else?
I'll keep digging through diagrams (and going crosseyed) to find another bundle with this group of wire colors...but I really think this is the one.
