I've got a potential project car idea floating around in my head & I need some help crunching numbers on some bolt on upgrades as follows....
Wilwood disc brakes for front and are they worth it for the rears?
Recommendations for bolt on suspension upgrades
Fuel injection, worth it or not?
Budget for stock engine & trans rebuild
OK, let it rip.....
There are alot of brake kits avaliable now, with prices all over the place. Since I have not gotten that far yet I'll see what other suggest.
On my suspension, reproduction R/T rear springs, Mopar 0.96" T-bars (still fairly mild, but I did not want a harsh ride.), Poly bushing, and aftermarket sway bars, and adjustable lower strut rods. My Charger has the old KYB gas shocks which work and have a stiffer ride. My Coronet has the RCD Bilstein shocks which ride nice, but are expensive.
I just installed the Edelbrock XT EFI on my 440. This is an expensive kit, but I liked how low the setup is so I can use my stock hood. I put a 6-pack hood on the car for clearance when I had the Performer RPM and Holley carb. The biggest issue is the fuel tank/EFI fuel pump. My '69 Coronet, the tank is fairly shallow, and the kit came with an external pump. I added a sump to the tank, and mounted the pump under the tank bu attaching brackets to the tank straps. It works good, but looks dumb. A custom stainless fuel tank with internal pump would be the way to go, but is expensive (like over $1,000.) Edelbrock just released a nice remote resivor with built in EFI pump that gets filled from the stock mechanical. That is a nice solution also, but takes up room in the engine compartment and it is still pricy.
If you have the hood clearance, you can use something like the MSD Atomic EFI which is less expensive. It is nice to have full control over the ignition curve and fuel, but retrofitting an engine that never came with it can get expensive.
Way too many options for engine and trans rebuild without more information.
If you don't mind the look, swapping in a Gen III hemi may be more economical.
I picked up a 2008 6.1L Hemi (50K miles) with NAG1 over drive trans and stock computer for $4,000 off E-Bay for another project car.
For the money you get a 425 HP EFI engine with all the accessories (high amp alternator, A/C compressor, P/S pump, ect.) and an overdrive transmission.
Other parts needed are a shifter from a newer hemi car (got a new one for less than $100), Reprogram the computer and modify the wiring harness (still looking at vendors), Not sure on the automatic computer yet, I read someone has a stand alone unit, but it is expensive.
Thanks for all the tips everyone. I had no idea that FI was that expensive.
For those who have done it, how difficult are the Vintage Air systems to install?
I have one on order for the '69 Coronet. Let you know as soon as i get it.
