- 10:31 PM
- Jan 16, 2011
- NorCal Sierras
RC/DH
Bolt-ons, some stuff has been covered already...
Magnumforce Racing, http://www.magnumforceracing.com/products.htm
Pretty much a whole tubular K-member & tubular Control Arms,
with a coil over shock various styles/sizes, singular pieces of full on front & rear end kit...
Big Brakes several different styles/price points to choose from,
from Pro-Touring to just Disc Upgrade,
you could get 2" drop disc spindles too help with geometry & a lower center of gravity,
or just reuse your own, depending on what options you chose,
front steer rack & pinion really nice too,
leaves a ton of room for headers & oil pan choices...
Rear suspension short arm 4 link helps allot just nor a racecar application,
with little to no frame/chassis modifications...
the sell various different shock options,
I'd suggest calling 408-559-6633 talking to Ron Jenkins, if he's available
QA1 Suspension Components , http://www.qa1.net/ , also has a bunch of front end stuff
Tubular K-Member $550 ballpark
Tubular Adj. Upper CA's $265 & up each
Tubular Lower CA's $337 ea. with sway bar mounts if wanted
tons of shock to choose from
Reilley Motorsports Inc. , http://www.reillymotorsports.com/store/home.php?cat=262
much like Magnumforce Racing, but square tubing, both front & rear suspensions
Probably the priciest of the after market kits but well liked...
RideTech Suspension Specialists , http://www.ridetech.com/store/musclecars/?subcats=Y&features_hash=V298.V328
Air & Coil over suspensions
About $5000 for a full front & rear kits
Summit Racing sells allot of QA1 stuff cheaper than you can get it direct & with free shipping over $99
SSBC bolt-on front disc conversions on your drum spindles $600-$1500+ depending on options
Dr.Diff for brakes conversions too
Viper Disc conversion too, they were kind of popular
98 Grand Cherokee rear discs, not too bad of a conversion
Not knowing what your plans are, how mild or how wild or how much you want to spend or how stock you plan to keep it, weather you want to retain the torsion bars or have a truly adjustable performance/handling/racing suspension, that will handle like it's on rails, compared to OEM style stock stamp steel components, it really hard to give prices or build costs...
You could always do the typical poly bushing $150ish & proper pins $150ish better ball joints $150-$200-$300, better brakes depending on size & styles $400-$2000+, bigger torsion bars $300, bigger or adj. strut rods $150-$200, bigger front sway bars $150-$200+ & add a rear sway bars $150-$200+ etc., not veer too far from the OEM stamped steel front end stuff, relatively inexpensively, rear XP or Hemi car springs or Eaton's $250-$300, sub-frame connectors from $150-$300...
all bolt on apps, no real fabrication or welding to speak of
There are many other options too...
