Mocajava
Well, sub frame connectors are in and look pretty good. Did the POR15 treatment on just that area and will address the rest of the underside once I get the sandblasting fine tuned. Had issues with the pot/grade of media and pressure needed...took some experimaenting to get it worked out. Added the picture of the interior floor boards and trunk to give a perspective on the "before and after". Not sure which direction I an going with a sealing coat, the POR15 or good primer for the interior floors and trunk. Leaning for the POR15 underside and interior gets the primer...I think. Hope I can get the surfaces cleaned well enough to make a permanent cap for both, time and level of "learned" experience will tell. More to come..... | |
Never having done a resto to this extent, I am searching for the best methods. Trunk floor (in part) needs to be replace. Been welding for 30 years so that part is easy for me...BUT how to preserve it is the big question. Not a painter other then home remodel and leery of the permanance of a primer plus a top coat as total metal protection. Am I being too **** in mandating that ALL the rust be gone or at best nuetralized? My thinking is that if it isn't totally gone, it will come back. I am told there are chemicals to spray on that will totally stop the rust and turn it into a paintable substance, just have no confidence in my own judgement along those lines. How much rust (even treated) can you leave and be assured you have stopped it's growth? What do you use to neutralize it and how far in removal do you go before you apply it? Would love to hear some feedback and instructions on this subject from the Professors at Mopar U. to keep me on track. I hate having to do things twice, and learning from others experiences is the easiest way to keep from screwing it up in my mind. Thanks in advance.
