PSA....
Brandy
Jack Stand Racer #6..and proud of it!
1:48 PM
Salisbury, Vermont
Thought this was worth passing along. If it saves even one of you from an accident, it's worth reading...
Michael E. Hanley Sr.
A 26-year old man decided to have a cup of coffee. He took a cup of water and put it in the microwave to heat it up (something that he had done numerous times before). I am not sure how long he set the timer for, but he wanted to bring the water to a boil. When the timer shut the oven off, he removed the cup from the oven. As he looked into the cup, he noted that the water was not boiling, but suddenly the water in the cup 'blew up' into his face. The cup remained intact until he threw it out of his hand, but all the water had flown out into his face due to the build-up of energy . His whole face is blistered and he has 1st and 2nd degree burns to his face which may leave scarring.
He also may have lost partial sight in his left eye. While at the hospital, the doctor who was attending to him stated that this is a fairly common occurrence and water (alone) should never be heated in a microwave oven. If water is heated in this manner, something should be placed in the cup to diffuse the energy such as a wooden stir stick, tea bag, etc, (nothing metal).
General Electric's Response:
Thanks for contacting us; I will be happy to assist you. The e-mail that you received is correct. Microwaved water and other liquids do not always bubble when they reach boiling point. They can actually get superheated and not bubble at all. The superheated liquid will bubble up out of the cup when it is moved or when something like a spoon or tea bag is put into it.
To prevent this from happening and causing injury, do not heat any liquid for more than two minutes per cup. After heating, let the cup stand in the microwave for thirty seconds before moving it or adding anything into it.
Here is what a local high school science teacher had to say on the matter: 'Thanks for the microwave warning. I have seen this happen before. It is caused by a phenomenon known as super heating. It can occur any time water is heated and will particularly occur if the vessel that the water is heated in is new, or when heating a small amount of water (less than half a cup).
What happens is that the water heats faster than the vapor bubbles can form. If the cup is very new, then it is unlikely to have small surface scratches inside it that provide a place for the bubbles to form. As the bubbles cannot form and release some of the heat that has built up, the liquid does not boil, and the liquid continues to heat up well past its boiling point.
What then usually happens is that the liquid is bumped or jarred, which is just enough of a shock to cause the bubbles to rapidly form and expel the hot liquid. The rapid formation of bubbles is also why a carbonated beverage spews when opened after having been shaken.
If you pass this on, you could very well save someone from a lot of pain and suffering.
I've heard of it blowing the door off the microwave.
Thanks for posting. Sounded so bizarre that I did a quick search to see if it was true. It is. Takes certain factors to occur, so it isn't super common, but it can do exactly what was described. I had no idea.
It would only take once to disfigure an otherwise lovely women or child...
I have also known about that reaction so I usually do not go near it for a few minutes to see if it does erupt and then use it for whatever I boiled it for in the first place. Thanks, Ghost...cr8crshr/Bill:thumbsup::thumbsup::thumbsup: :usflag: :usflag: :usflag:
Wife bought a new but "remanufactured" big-arse microwave off eBay damn near 20 years ago.
The thing is a total beast to this day and will cook anything faster than what it says on whatever
products' package it is you're heating, although the LCD readout went useless years ago.
I put stuff in it and step away; I never stand in front of it.
It's quite handy as long as you know the limitations of safety - and it's just me and the wife, so...
Oh, and I own a leak detector for microwaves, too - and yeah, the thing has some leaks. :-)
There is a Lot More to This to Be Discussed, but I'm sure it would be "moved" to another forum topic. This should be taken Very Seriously...
I did hear that a while back , I decided to get rid of the microwave about 10 years ago after I heard they destroy the nutritional value of the food put in them.
Unrelated but still noteworthy, a trick I learned by cooking regularly is to take a section of paper towel and get it damp then lay it over small bowls of stuff you're heating up. Like butter melting, and sauces. Keeps the inside of the microwave clean. lol....
I’m sure I’m not the only one who uses distilled water for coffee sometimes.
We stopped using the m wave for heating water since we started using Keurig coffee machines. We just run the machine sans coffee K Cup and do hot water that way. Hot choc is also in K Cups.....
Wow, to think of all the times I’ve heated water for recipes that call for boiling water. Often in a casserole dish covered, or glass measuring cup. Have reheated my cold coffee many times as well, but no longer than 30 seconds. And read that you shouldn't reheat in disposable cups.
Being a pasta nut, often making enough for leftovers, recently heard that it can be deadly to leave that out too long before refrigerating. Same with rice. Another thing I’ve done for decades.
Thanks for sharing this info and will pass it along to the family.
Our microwave quit on us years ago, and we never replaced it. Oddly, we have somehow managed to survive.
I don't know that I could live without a microwave. But I never heat anything to boiling in it. 30secs to a minute, to heat cold coffee and Baileys. That's it.
