pSpecs for 318 engine
bob32268
3:40 AM
Johnstown, Pa.
What is the recommended spark plug for a Coronet with the 318 engine and also the oil filter. The "glovebox booklet" is not very specific on this.
It recommends J14Y..or P3-6p...Is J14Y a Champion plug? Not sure of the brand for the P3-6P....
Tks,
Bob32268
Tks,
Bob32268
J14Y is a Champion plug. Just look it up by application. Champion has changed numbers a few times and the interchanges aren't always correct.
318 will have a long reach plug Champion N14Y was common in the 60's now N12YC is mostly used.
Do a search for cross reference to NGK, Autolite, etc.
Oil Filter Wix standard 51515 or Wix 51515XP Bosch 3500 K&N HP-3001 and the list goes on and on.
No we can only guess you are looking for a LA 318 and not a 1966 and older Poly 318.J12YC if that's the case. Oil filter will be the same.
It definitely is the Poly 318, thanks for your help.
Bob32268
