Pulley for power steering pump - compatibility question
munger77
2:44 PM
Atlanta, GA
My pulley is bent; if I can't straighten it I'll need a new pulley.
440 with A/C. Federal pump is freshly rebuilt; the style used from 1963 - 76 give or take.
My PS pump is stamped 2537955. My single V Pulley is 7" outside diameter, press in with no key lock.
Does anyone know if other brands of pulleys will fit my Federal pump?
Might check out a you-pull-it junk yard.
If I can't find one, is there another aftermarket or more recent PS assembly I can use on my 440 with AC?
I will take a picture of the one that is on the belvedere. Its a 66 and I wont be using it. Its from a 318 Poly but Ill look at the number. Never mind not even close i think.
You can check with Hart Brothers Core Co. in Albany Oregon. I have worked with them before on getting p/s pullies.
Thanks Hashmaker and BeepBeep. I just finished cleaning up the garage; quite a job today. I'll try to straighten it out and if not call Hart Bros Core in Oregon unless I find another 7" that isn't too pricey.
