Blazer85
Hello,
I have a 1968 roadrunner with a 383 and a 4 speed. It is a 71 motor (in it when purchased) and custom built brewer 833 transmission to make the engine work with the mounts in the car. The engine is getting some long over due work and it needs to come out. Would it be easier to somehow slide the motor forward and just lift it up? Or unbolt the driveshaft and take the trans out with it? The trans is not getting any work done on it. Also there is no heater in the car, so am I missing anything other than remove hood, pull radiator, unbolt trans from engine (or driveshaft from transmission), unbolt headers, disconnect coil, pull carb, lift out?
Sorry if this is in the wrong spot, newb on here and couldn't find this info anywhere.
