Helping a friend trying to get his 69 Hemi Roadrunner up and running and tried to do a backyard front end alignment on it yesterday. He plans on getting a shop alignment but I thought I would get him reasonably close first. With my little camber/caster gage I got the camber set around 1/4 deg negative with rear bushing adjuster moved all the way in to get as much caster as possible and then decided to move on to tracking and toe where I ran into a problem adjusting front tracking.
Problem 1 - I think he misaligned the column shaft when installing the coupler to the gear box. But not knowing that, that's what I started with. I started using a 5 ft straightedge laid against the side wall and gaging how the tire was aligning to the rocker panel to get the wheels pointed straight ahead with gear box centered (only it wasn't). The left side straightened out fine with a few turns of the tie rod sleeve. The right side was toed in pretty good so I started turning the sleeve to shorten the tie rod assembly and move the front of the wheel out. Turned and turned and finally ran out of threads and the tire is still toed in quite a bit.
Problem 2 - Something is apparently wrong so we turned the wheels lock to lock, counted turns of the steering shaft (4-1/2 turns - manual box) and came back to center (2-1/4). Surprise, where he thought the box was centered, it wasn't and the column shaft wasn't indexed correctly to the box. Decided to skip that issue for now and concentrate on finishing the backyard alignment. With slight adjustment the left side straightened back out but the left side is still toed in pretty good (combined about 3/8 to 1/2 inch toe in). And I'm still all out of tie rod adjustment on the right side. So how does that happen? Been a long time since I've had a pitman arm off of my GTX's gear box but I think it has a master spline and will only go on one way. The only other thing I can think of is the right side tie rod sleeve is longer than it should be. Didn't think to tape them but didn't seem to be of different length. Tie rod ends are all new and of same manufacturer. This car is an original Hemi car but he started with basically a rolling bare shell with VIN and has restored and rebuilt the car from there, sourcing parts from everywhere. What else could I be missing?
