Paul_G
- 1:42 PM
- Dec 24, 2013
- Surprise, Arizona
This is the no muffler kit. I re-used the existing Cherry Bomb chambered mufflers. The kit does not include the extension pipes from the headers or manifolds. You have to get those separately. I used the Hedman 18806, 5 1/2" offset ones. Long enough to cut in the middle and line up through the cross member openings. I also used some Summit 681250 lap joint band clamps to make the exhaust removable if and when needed. I did tack the pipes together under the band clamps so they dont move. If you cant weld, and are working on the floor, this would be a real PITA.
