Qa1 Kmember
Pool Fixer
9:23 PM
long islamd, ny
68 Charger
After 10 years of it sitting collecting dust, My Qa1 kmember is going to be installed. all of the front suspension components as well. I'm not going coil over- retaining stock config but all new and in some cases upgraded parts.
-FF tubular UCA's
-Qa1 tubular LCA's
-Idler
-Pitman
-Inner tie rod ends
-outer tie rod ends
-FF adjustable strut rods
-new 1" torsion bars
I have a B body hellwig antisway bar on the stock K now. While the new LCA's have the mounts for the end links, it looks like the mounting points for the bar on the neww K member won't work. The way the b body bar is bent, the existing k member mounts are almost dead even with the front k member bolts. new K member has those mounts set back further.
I've read that an E body bar works. Looking for a recommendation/part number for a bar that will fit. I looked on youtube and the web and a lot of people who put this kmember in go full balls coil overs. I don't see many installs where they use this K and retain the torsion bars. car is a cruiser so i don't need some super canyon carving bar...
All my new parts are 8-9 years old but I basically put together what qa1 now calls the Level 1 kit. I see the sway bar they list for it in the parts breakdown is #52860 so I ordered that one.
I just did this setup on my 69’ Coronet R/T
Still haven't installed it.. running out of gas, I'm gettin freakin old lol. prob now a winter project. I have a lift in my shop and heat so it's not so bad.
trying to work out a way to do this out the bottom with a 4 post lift. Rollin's pic has me a little rejuvinated though. I did get 2" drop spindles, new old stock ball joints, and the proper fitting qa1 sway bar so I'm all ready to go as far as parts.
Glad I brought your excitement level back up a notch.
On the 4-post you are going to have to get the front lifted off the suspension regardless. You will probably need a cross beam to hang the engine and the rest won’t be a huge deal.
I pre-assembled everything including the brakes and steering parts.
In my situation I also bolted the engine and trans to the K-member and put it all in from the bottom.
I have 2-post lifts and a bobcat with forks. It is also a fresh build that has a new motor/trans so I had a little more going on than you do.
If you get the front of the car high enough off the deck of the lift and the engine hung from above I don’t think it will be a big deal to slip the stock front end out and the new one back in.
what I’m thinking is exactly what you are saying. Hold the engine up with a beam across shock towers. I’ve seen this done in a couple of you tube videos of this swap. Back car into lift up to rear of kframe. Tie down rear end with chain/HD straps. This all taking place at work and I have a fork lift too. I also plan on assembling most of it since I have all new parts
