QA1 Upper Control Arm Camber Bolt Torque Specs 70 ft/lbs?
themechanic
Oklahoma is OK
3:16 AM
Moore, Oklahoma
I just installed a pair of upper control arms from QA1 on my 69 Coronet. The instructions from QA1 say to, "tighten the camber bolts to 70 lb. ft".
The FSM says to tighten the Upper Control Arm Pivot Shaft Nut to 130 foot pounds.
The difference is the factory rubber bushings vs urethane bushings in the QA1 control arms.
So, what is correct?
You guys actually put a torque wrench on that stuff?
I used the QA1 70 ft lb spec. I had the alignment done today. Here are the results.
