SOLD Quality rebuilt Mopar distributors
HALIFAXHOPS
MSGT(ret) and MOPAR only distributor rebuilder!
7:15 PM
Halifax, PA USA
Feedback: 116 / 0 / 0
Once again rebuilt Mopar distributors, all clearances checked, disassembled, cleaned, brought back to factory specifications then re lubed and assembled NOS or NORS points and condensers installed so no premature fails with the junk new components that have a very high fail rate. Then ran on one of my six distributor testers by needed RPM. Can curve also if needed using all oem parts no welding and grinding. Have a few hundred cores to choose from so I only list the completed units don't see what you need just ask.
SLANT
63
170/225 2098671 17/3
66
170 2444255
LA
MP
3 no tag 72 up electronicx
! nice curve for a small cam
64
273 2444448 13/4 MAN/AUTO A
65
273 2444791 21/5
318 2444291 48/4
273 2444853 IBS 4013 A body only 37/4
67
273 w/petronix 2642242- IBS 4013a 7/7
273 2642242 IBS 4013A 7/7
273 2642238 7/7 A/B
318 2642218 16/7 A/B/C
318 2642718 at 18/7 B/C
69
318 2875796 46/8 A/B/C
340 2875782 IBS 4015b x3 A ONLT MT 2)8A and 4B date codes
318 2875796 A/B/C
70
340 3438325 A/E body 2/0
340 3438317 IBS 4018 mt A/E
71
318 3438225 42/0
340 348522 IBS 4018C 38/0
318 3438225 49/0
72
340 3656278 22/2 A/B/E
318 3656587 17/2 A/B/C/E
73
360 3656780 40/2 EARLY C
360 3755365 18/3 C
75
318 3874090 38/4
B
Accel 30302
64
361 2444241 43/3
65
361/383 (2) 2444676 8/5
67
383 2642728 32/7 B/C
68
383 2875354 3/8
71
383 3438534 21/0 B/C/E
383 3438534 25/0 B/C/E
72
400 365696 15/2 B/C
400 3656593 49/1 LATE B/C
76
400 3755157 47/5
RB
MP aluminum case tach drive 4120942 54/5
36590432 49/5, 24/3, 40/9
62
361/383 2095836 2/2 C
63
413 209834 IBS 4011a tACH DRIVE
64
2444361 413 (300) IBS 4011C 300
65
413 2444867 48/4 C
413 2444869 C
66
440 MT 2642252 35/5
440 MT 2642251 2/6 C body
440 2642252 48/5, 28/5 c/d
67
68
440 2875362 350HP 46/7, 52/7 C
69
69 440 (350 HP) 2875754 33/8 C body
70
440 3438219 350hp 6/9, 37/9 C
71
72
440 3656341 12/2 B
Early pre 1960
IAT 4101
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IGS 4201-1 needs a vac advance
IBJ 4302A 56 Desoto
IBJ 4301A 56 Dodge
IGS 4111-1 41 dodge D20
IGS 4101
How much for the 62 361 2 points?
2/2 is the date code second week of 1962 175 shipped lower 48. Shoot me a pm if interested.
Ray
Ray,
I need a mechanical advance electronic for running tests on new motor builds, and for consistent runs at the drag strip. Basically I'm looking for something you would use on a bracket car, and in my mind that would be the equivalent of an old Mopar Perf aluminum tach drive unit, like the one that used to come in the chrome box kit. Is that something, preferably economical that you can suggest that I can buy new?, or that you may actually have that will work for me? I would prefer to find something built for an RB, with an adaptor to run on a B engine when needed. If that particular unit is too expensive, is it possible that I could just use a distributor with a dual mech/vacuum advance and just don't use the vacuum?? Or would that not give me the desired curve from initial timing to full advance like the tach drive units do?? TIA for any help you can give, Lefty71 (Dave)
No adapter here, can make one come in full mech between 1500-2700. either lock out the vacuum advance or not it is easy. That work? Give me curve specs. Tach drives get pricy for what they are. Prob 150-180 depending what parts. You can just use Mechanical if you want if it has the right curve in it already. Prob want 34-36 total.
Ray
I think we are on the same wavelength here, but what I need help with is figuring out the curve specs. I don't need a tach drive at all (for a tach), I need to duplicate the curve they used to come with "out of the box". Luckily I still have one here, in use on a car, that I should be able to figure out the specs, meaning is there an identifier to the springs and plate?? that I can use to have you do a rebuilt mimicking these specs for me?? It don't have to be pretty, and it doesn't have to be tach drive, just match up the job that my old one does. Running strictly from memory, that's about 5BTDC initial to about 36-38 total all in at around 2000rpm. Does that help me pricewise if I can use any old RB core, with the vacuum advance removed and set-up as described above?? Thanks, Lefty71 (Dave).
Send me the one you want copied. Easy for me to do.
That might be the easiest way to go. What is the least I can get away with, no tach drive, still $150-180, or would it be less? Thanks again.
Should be can be less also shoot me a pm.
Ray
Perfect, i'll be in touch later on today. You are an asset to the group.
SLANT
63
66
170 2444255
LA
64
65
273 2444791 21/5
318 2444291 48/4
67
273 2642238 7/7 A/B
69
318 2875796 A/B/C
70
71
318 3438225 42/0
318 3438225 49/0
72
73
360 3755365 18/3 C
75
318 3874090 38/4
B
Accel 30302
64
361 2444241 43/3
65
67
68
383 2875354 3/8
71
72
400 365696 15/2 B/C
76
400 3755157 47/5
RB
62
63
64
65
413 2444867 48/4 C
413 2444869 C
66
440 MT 2642252 35/5
67
68
69
70
71
72
440 3656341 12/2 B
Early pre 1960
IAT 4101
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IBJ 4302A 56 Desoto
IBJ 4301A 56 Dodge
IGS 4101
updated
SLANT
63
66
170 2444255
LA
64
65
273 2444791 21/5
318 2444291 48/4
67
273 w/petronix 2642242 no tag
273 2642238 7/7 A/B
69
318 2875796 A/B/C
70
71
318 3438225 42/0
318 3438225 49/0
72
73
360 3755365 18/3 C
75
318 3874090 38/4
B
Accel 30302
64
361 2444241 43/3
65
67
68
383 2875354 3/8
71
72
400 365696 15/2 B/C
76
400 3755157 47/5
RB
MP Electronic 36590432 49/5, 24/3
62
63
64
413 2444361 (300) IBS 4011C
65
413 2444867 48/4 C
413 2444869 C
66
440 MT 2642252 35/5
67
68
69
70
71
72
440 3656341 12/2 B
Early pre 1960
IAT 4101
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IBJ 4302A 56 Desoto
IBJ 4301A 56 Dodge
SLANT
63
66
170 2444255
LA
64
65
273 2444791 21/5
318 2444291 48/4
318 2444259 29/4 AT B/C
67
273 2642238 7/7 A/B
68
340-4 2875105
IBS4015A AT A ONLY
69
340-4 2875782
IBS 4015C 4/b MT a only
318 2875796 A/B/C
70
340-4 3438325 42/9 AT A-E ONLY
71
318 3438225 42/0
318 3438225 49/0
72
73
360 3755365 18/3 C
75
318 3874090 38/4
B
Accel 30302
64
361 2444241 43/3
65
361/383 (2) 2444676 8/5, 6/5 AT=MT
67
68
383 2875354 3/8
71
72
400 365696 15/2 B/C
400-4 3656329 22/1 B ONLY
76
400 3755157 47/5
RB
62
63
64
413 2444361 (300) IBS 4011C tach drive C only
65
413 2444867 48/4 C
413 2444869 C
66
440 MT 2642252 35/5
67
68
69
70
71
72
440 3656341 12/2 B
Early pre 1960
IAT 4101
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IBJ 4302A 56 Desoto
IBJ 4301A 56 Dodge
Great to hear it! That was the mechanical only one? Hard to keep track of them.
Hi Ray- yes it was for the 383 4 barrel points distributor. Really nice work- thank you. I’ll be in touch when i start working on my barracuda.
Updated
SLANT
63
66
170 2444255
73
225-1 3755042 51/2
LA
64
65
273 2444791 21/5
318 2444291 48/4
67
273 2642238 7/7 A/B
68
340-4 2875105
IBS4015A AT A ONLY
69
318-2 2875747 29/8 AT B/C
340-4 2875782
318 2875796 A/B/C
70
340-4 275HP 3438319 9/B IBS 4015C MT A/E
318-2 3438225 7/9 AT B/C/E
71
318 3438225 42/0
318 3438225 49/0
72
340-4 3656278 22/2 MT-AT A/B/E
318-2 36567275 15/2 MT-AT A/B/E W AIR PUMP
73
340-4 240 HP 3656771 41/2 MT-AT A/B/E
360 3755365 18/3 C
75
318 3874090 38/4
B
Accel 30302
64
361 2444241 43/3
65
67
68
383 2875354 3/8
71
72
400 3656593 11/2 AT-MT B/C
400 365696 15/2 B/C
400 3656593 49/1 B/C
76
400 3755157 47/5
RB
MP 3690432 37/0
MP ALUM TACH DRIVE 412092 48-4
62
63
64
65
413 2444867 48/4 C
413 2444869 C
66
440-4 MT/AT 2642252 4/6 C/D
440 MT 2642252 35/5
67
68
440 2875209 375HP 3/7 AT B/C ONLY
69
70
71
72
440 3656341 12/2 B
73
440-4 220HP 3755157 26/3 AT B/C
Early pre 1960
IAT 4101
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IBJ 4302A 56 Desoto
IBJ 4301A 56 Dodge
SLANT
63
66
170 2444255
73
225-1 3755042 51/2
LA
64
65
273 2444791 21/5
318 2444291 48/4
67
273 2642238 7/7 A/B
68
340-4 2875105
IBS4015A AT A ONLY
69
340-4 2875782
318 2875796 A/B/C
70
71
318 3438225 42/0
318 3438225 49/0
72
73
360 3755365 18/3 C
75
318 3874090 38/4
B
Accel 30302
64
361 2444241 43/3
65
67
68
383 2875354 3/8
71
72
400 365696 15/2 B/C
76
400 3755157 47/5
RB
MP 3690432 37/0
62
63
64
65
413 2444867 48/4 C
413 2444869 C
66
440 MT 2642252 35/5
67
68
69
70
71
72
440 3656341 12/2 B
73
Early pre 1960
IAT 4101
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IBJ 4302A 56 Desoto
IBJ 4301A 56 Dodge
Will be able to reply on Sunday, no web service where I will be at.
