E911manager
New Member
New mopar guy and I need some help..
Does anyone know if you can use a older LA style cam in a later model magnum engine? Two issues I am concerned about.
1. The LA cam has a longer snout for the manual fuel pump. Will this hit the timing cover if I use the magnum timing cover?
2. The LA cam is supposed to have oil holes for the bearings. What issues will this cause if any?
Been on magnumswap.com but doesn't really answer these questions.
I have a 1994 360 magnum all stock and want to put a mild cam in it. I am going with a carburetor on a Edel 7577 intake so I can keep the factory AC compressor (in case i decide to put air on later). I plan on running an electric fuel pump also..
