fmahannah
1963 Dodge Polara Max Wedge Tribute
- 5:42 AM
- Sep 25, 2014
- Dahlonega, North Georgia
I have a 63 polara 500. The engine is a 62 413 60 over. Right now it has ported 906 440 heads on it but I want to put wedge heads on it along with crossram setup to be more like a wedge car would have been. With original heads and intakes so pricey, I am considering the mopar performance cast iron heads supposedly designed to replace the 62-64 wedge heads. For example the P5007494 or P5249824. My concern is that I saw something about for certain valve sizes the cylinder wall needed a relief cut into it to clear the valves?
My block does not have the relief cutouts so I have no idea which heads I can use without having to machine or change the block?
Might consider aluminum wedge heads if anyone has recommendations, but needs to be bolt on mod.
Thanks
Thanks
