65 Coronet
I have Crane adjustable rockers and the install procedures state:
"On a hydraulic cam rotate the engine until the exhaust valve starts to open. Now, set the intake valve by tightening down the adjusting screw until there is no end play in the pushrod. This is called zero clearance. Now tighten the adjusting screw one complete turn and tighten the lock nut."
My question here is when it says "no end play" does that mean the pushrod should not turn? I would think not as I would think that would collapse the lifter. Should "no end play" be where the pushrod is just set in the lifter and rocker securely and when trying to move the pushrod up and down you can feel the lifter compress and release? I don't want to tighten them down too much.
Thanks,
Mike
Thanks,
Mike
