rad fan info needed....
63dodge440
6:45 AM
indy
i need info or pic of the right rad fan i need to find for my 63 dodge 440 that has a 440 in it thanks....
i think the older fans were 4 blade,then later went to a siz blade and cluch fan but not sure i went with a 65 six blade,until i know differently...
What ever you do don't use a flex fan, you will have over heat problems. I bought a 7 blade fixed fan that had a Mopar part # in ink, the number crossed for 64-65 B cars. The 7 blade (17") cools perfectly. I would prefer a clutch type but I got what I got. I threw out the flex fan the PO installed and had overheat problems at idle in hot temp.
