Speedbird
Bird of Pray
I pulled removed the original radiator from my original radiator support,
I my limited experience there usually are little square nuts on either side.
This car only had them on the driver’s side.
The passenger side, top and bottom had holes with assorted odd fasteners.
The bottom his hard to see but the top is obvious.
That's a hole poked through on the passenger's side on the bottom.
I can only guess that as this car was being built in St. Louis they drilled some holes and put what ever they had on hand to get it out the door.
Any one else run into this or is it normal?
If someone was doing a kon-Coors restoration, would they put this stuff back in or would they “over restore” the car to a state it seems to have never been in?
Oh, I’ve also got the top left of someone else’s build sheet.
It looks to be a special order car. It was under my front black bench seat.
Maybe that goes under "Lost and Found"?
