Remusa12
I have a 73 charger with a 440 with the higher 78 amp alternator it had issues charging before so I put a new regulator in the car and it fixed my charging issue. However it still has an issue where the radio will cut out when I apply the turn signals and brake lights at a stop sign. It's an aftermarket pioneer, I also have 2 electric fans and drive with headlights on. I can see the needle dip into discharge when I'm stopped with every thing running and it can be fixed with a little more rpm at idle. My guess is the alternator doesn't produce enough amps at idle which is set at 650 but I need to put it up to 1000 to work.
I don't know my pulley ratio but it's using all factory parts so do I just need a higher amp alternator.
