Rear defroster / speaker adapter from E-body
Charger Fan
11:29 AM
Jupiter FL
I know these adapters were not made for nor will fit a B-body package tray. Has anyone taken one and been able to successfully modify the installation to make it fit and function on a B-body?
Not on a 71-74, but that adapter marketed as being for E-Bodies will fit and work on a 70 B-Body. A spacer and a longer fastener can be used to secure the one leg of the adapter to the package tray. I may have reclocked the blower motor on its mounting plate for the hose to duct positioning.
I have on my 71, was not too difficult at all. I did make and weld in 1 small bracket underneath to support the adapter.
I think they were offered on 71-74 B’s? Like a S/E
I had an offset adapter on my 68 Cuda coupe. Bolted in, drilled one hole. And used long screw to stabilize the motor side of the adapter.
I had to extend the outlet tube.
I didn’t try hard since my car was being dissasembled for a deep body job, but on a first try I couldn’t. The rear bracket provision did meet with deck lid torsion bars as far I recall.
But it seems is posible per the 70Chall440 pics making that custom job.
It really was not hard at all, just had to make that bracket as I recall. I have one in my 73 Cuda as well and my 68 Cuda came with some form of rear window defogger but I have not looked into that all that hard yet. I have some more components for another rear window defogger system but I think it is for a C body.
Yeah it cleared ok.
Thanks for all the info.
On a different subject, what is the sound barrier/insulation brand you can see in the pictures you posted? Installing that is coming up on my "to do" list and with so many brands available wasn't sure which is a good one?
I have the rear defogger option in both of my red 70 Charger R/T S.E. and my red 70 Challenger R/T S.E.'s. They both appear to be the same mounting brackets, harnesses etc from what I have ever been able to tell. However, I have never removed either one. I don't seem to have any pictures of the set up in my Charger, but I did take some of the srt up in my Challenger.
On this car I used several different brands of insulation however what you see in the pictures is called Siles Hybrid, I got it from Amazon. It works pretty well, definitely very sticky. It has a bhytl backing and adheres well to most surfaces. I did pretty much the entire car in it except for the top of the package tray, there I used a foam product that I also got from Amazon.
https://www.amazon.com/dp/B0B6JKF9SC?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_8&th=1
Dutchman panel along with the package tray distance is way shorter on 3rd gens, so provisions on them are un existant and this was not an option
