Rear drums 64 sportfury not holding.
Nick ciavarino
5:58 AM
New castle pa
Booster rebuilt new master cylinder with prop valve mounted under its a pirate jack combo,front discs. master bled,lines bled,car on jacks front discs work fine drums fit kind of snug with movement no e brake ever hooked up .?
Can we assume the rear drums are properly adjusted?
Mike
You probably need to adjust the booster push rod, to tune in the rear brake actuation.
