Rear Quarter glass replacement..69 Superbee
bh146
New Member
9:02 PM
ottawa
Hi Gang:- 60 Coronet Post car Having a stuggle trying to remove quarter glass out of the frame.- Noticed Replacement glass has 2 pre-drilled holes approx one inch from top & bottom- Assume there's a clip/fitting inside the channel but yet been able figure out how to remove it from the frame.
Anyone ran across this gremlin & beat it?
Can get some pic's up if need be.
t.y. Lorne::headbang:
I'm in the same boat on a post RR... having a hard time figuring out how to get to the securing bolts...
If anyone finds this old thread on how to do this; There are two rivets at the top and bottom of the front vertical stainless that have to be drilled and that is removed with the glass, then the glass slides out the top of that stainless support on two tracks.
