Rear
Data Plate
6:48 AM
New York
A guy by me is selling he said it’s a 8 3/4 rear section but the part number is 1634985 and a date code A24 I’ve seen 741 742 and 489 but never a 985 anybody know what it’s from
pnora
6:48 AM
Ishpeming, Mi.
Used 57-64
Cranky
Banned Henchman #27
Staff member
5:48 AM
Pasadena, Texas
Would it work ok in a 69 charger
Depends on what it came out of. Is the whole rear end or just the third member? I'm thinking third member since you said section. I heard the center thrust pin is a different size than the others so....not sure. Never messed with the 'really old' stuff :D
MoparLeo
NRA BENEFACTOR LEVEL LIFE MEMBER
3:48 AM
Moreno Valley, So California
Agree. Need to know what it came from if you want to use the complete rear. If only the pumpkin , should not be a problem.
The 742 equivalent is a very good unit.
Here are some dimensions:
http://www.moparts.org/Tech/Archive/axle/16.html
Casting numbers 2070742 (used from 1961-1969) and 1634985 (used from 1957-1964) identify the 1 3/4-inch-diameter 10-spline pinion shaft, and are commonly referred to as the "742" case
#41
3:48 AM
WA
985 was in my 57 Coronet before I swapped in a more modern axle. Sorry... cannot can't add any help about compatibility of 985 with more modern yokes and axles.
Cranky
Banned Henchman #27
Staff member
5:48 AM
Pasadena, Texas
If its got tapered axles (64 and under) pass on it.
Well, that shouldn't matter to the 3rd member but like I mentioned eariler, I've read/heard that the center thrust pin was different (shorter?) than the other 3rd members.....
Dave6T4
6:48 AM
Ontario, Canada
That 985 is like a 741. 8 3/4, small pinion shaft. It would be good behind street small block. Still stronger than any Chev rear end.
Data Plate
6:48 AM
New York
Thanks for all the helpful info I’m gonna pass on it he wants like 800 which I thought was high has 456 gears in it to steep for me anyway
