D
Deleted member 214
Guest
I have a 70 Road Runner original V code 4-speed car. I bought it from a buddy who found it with no engine or tranny about 15 years ago, raced it some, then put in a street motor he had in the garage using a 74 block and a 23-spline. I bought it about ten years ago. 906 heads, stock compression, stock cam .450 lift, stock six pack intake and carbs, factory HP exhaust manifolds, 3" pipes. I put in a Tremec five speed a while back - used to drive to the Mopar Nats from Fort Worth. 74 Dart disk brakes up front.
It has been smoking some, fouling plugs, little backfiring out of the exhaust when I back out of the gas. I'm a parts replacer and not a diagnostician so took it to Motorheads in Elyria, Ohio. http://motorheadsoh.com/Home_Page.html. They specialize in Mopars. Hoping it was carbs and timing, but no such luck. Need a full rebuild. Heads, pistons, cam, the whole enchilada.
I'm a street cruiser, not a racer. However, since I gotta spend the coin anyway, might as well spend a few extra and make it run real nice. The plan - Edelbrock Performer RPM heads, Comp Cams Xtreme Energy 21-227-4 Advertised Duration 275/287 (231/237 @050) .525/.525 lift, ceramic coat headers. The fingers on the clutch were dangerously worn so the clutch goes bye-bye. The shop recommended a McLeod twin disk unit, light pedal but can handle the HP. They are matching the pistons to the heads and block deck for good quench. I have a correct date code block in the garage so will have that one built instead of the 74 block.
Whaddaya think, kiddies?
