recommendations for a QUIET fuel pump
jprather
1:49 AM
Tennessee
looking for recommendations for a QUIET electric fuel pump..72 sat, 440. I have a summit fuel pump on it now, and it is NOISY !
Summit markets an edelbrock pump as a "quiet flow" pump. Its not cheap.. EDL-1791 or 1792..
I use a trick flow on one car, a Mallory 250 on the other. Sure cant hear either one (with tbe engine running).
the one on it now sounds like a power steering pump a quart low !
My Mallory 140 is pretty quiet, at least compared to my old Holley "Blue pumps". The Mallory does pump fuel very well too.
really dont want to drop the tank
Usually- unless you are running a serious race carb setup, the mechanical pump is fine.
850 demon.. already have the new 3/8 fuel line in and the summit pump on, just dont like how load this one is
I have Holley Blues on drag Duster. I like the fact you can hear them. (Quickly drowned at WOT.) But I guess it would be annoying on a street cruiser. With today's EFI options? I'm sure more of an issue. I haven't heard any vendor boasting high flow/low noise pumps. Especially any of significant size and flow volumes.
=tbn:ANd9GcQ7Om0HORIJoJrX4q0gDy5ifB6Sexcv5LFTps6x9FUagpXcy6Nx9YD-vUi1fzvBet9o1bdLiKOT2A&usqp=CAc.png
A bit pricey but can't I cant even hear if it's running. To verify it was working I actually had to look at my fuel pressure gunge and that's with the car off...
I actually have the dual pump good for 1600 EFI hp / 1800 Carb..
https://www.holley.com/products/fue...2bEnvvvJv6x74KITGWZ2-Fqf2PGnmqlgaAvknEALw_wcB
12-600 Holley gets you 600 EFI or 730 Carb HP
  • 65 GPH HP In-line Fuel Pump
65 GPH HP IN-LINE FUEL PUMP
Street/Strip Carb or EFI Applications Supports up to 600 EFI or 730 Carb HP Compatible with Pump or Race gas
PART# 12-600
$300.95
Free Shipping
In Stock
running an 850 demon carb.. will this feed it ??
If you are in the 500 HP range you want a fairly high output pump IMHO. I wouldn't rely on a mechanical, but that's just me. Couldn't hear the 140 Mallory during cruising, fairly loud mufflers though. I do like to hear the electric pump running before I hit the start button.
i agree, I wanna hear it before I start the car, but not after, this thing is LOUD
