ValleyoftheSuns
I have a door mirror that got knocked/broken off.my 65 coronet...I realized the only way to get it out was to unatt
atch the three wires and pull them out through the small hole in the door...I had a friend with a replacement ..from a 69 dart and it looks identical except the wires are a little longer and the toggle/joystick is different...but here's my problem:
I cannot remove the 3 wires from the joystick side in order to feed them through the door...it's like they're permanently pressed in?.....do I simply need a earlier model mirror that allows me to disassemble the toggle? Otherwise the feed hole through the door is simply too small for anything other than the 3 wires....please help! Thanks
