Removal of A-pillar drip rail
George Diniz
New Member
6:49 AM
Greensboro, NC
Has anyone removed the drip rail from the A-pillar? Not the trim, but the actual metal drip rail? I wanted to salvage it so that I can replace metal and door post. I thought that I had found the spot welds, but they weren’t spot welds. If anyone has removed these drip rails, without destroying them, I could use some pointers on the best way to do that.
Thanks!
Thanks!
Thanks to anyone who may have given my inquiry any thought, but I have since worked through the problem successfully.
Please do share! I have no idea how that can be done, so I'd love to learn!
I'm thinking cut them and every few inches leave a short piece of the original to hold it together while stitch welding the cut off parts? I did a K frame like that and it came out well. I solid welded the K frame once all the cut areas were tack welded.
On what type of car? On my 71 SSP the driver side came off by taking the screws out and cutting a couple spot welds. The passenger side was held on only with the screws. The replacement A pillar I tired to steal the drip rail off on the driver side (mine was rusty) was a complete nightmare with how many spot welds there were.
