remove the iner wheel bearing seal.
ddpsnake
1:14 PM
Belleville Canada
working on my 8 3/4 housing ,what can i use to remove the wheel bearing inter seal on my housing.
I use a 1 1/4" open end wrench... Hook the long side of the wrench behind the seal & use the wrench as a lever to pop the seal...
I think I heard the axle end can be used also. Never tried it since I also have a slide hammer.
Mike
I did this recently - used the end of the axle as suggested above. Just pop it in a small amount and then pry it out. If you have the correct tools you can obviously use them.
I've used the axle end technique on lots of axles, the7.25, 8.25 & 9.25 mopar, the 8.8 ford & 10 & 12 bolt Chevies but the 8.75 axle inner seal sits pretty deep, I've never tried using an axle cause the angle would be pretty steep....
I didn't imagine it....it worked fine.
Not saying it didn't, just saying I haven't tried it.... I have a 1 1/4 wrench that I've used on all 8.75 axles I've replaced inner seals on for the past 40+ years....
