removing dash in '69 RR
vitamin c orange
9:05 AM
Central Indiana
I have a new dash bezel that I need to install. How do I remove the dash to get to it?? Do I need to remove the entire dash (top) or just the lower dash around the steering wheel and speedometer?? Is it complicated?? I don't want to break anything. Thanks
if by dash bezel you mean speedo/gauges you need to only remove lower dash its not easy but not that big a deal screws are hard to reach though. best wishes. cd
fastners, under the dash kind hard to see,,kinda have to feel your way around...
Take your time,Switch bezel looks like it will come out easy when you take the screws out but with the wire plugged into it it dosent come out all that easy,dont forget to un plug the speedometer cable from the cluster.Its a royal PITA but with patience you will get it,I hope I never have to take mine out again. Good luck
