removing spot welds on quarter trunk extension?
blazer 2010
vernon.B.C. Can.
I,m trying to remove the trunk extension on my 67 belverdere in one piece to fix a dent in the corner,is has to be removed to fix it but was wondering what to use to get in there,a drill is to big to get at the spot welds.What worked for you.
you have one on the inside of the trunk close to the back, cut the drill bit and make something custom unfortunately you must improvise the rest will be from beneath also do it from the opposite side you should be fine
Shortened shaft on spotweld cutter in a right angle air drill would probably do it.
